Hi guys! While not necessarily Pantera specific, I did develop these for use in my Pantera and have seen a number of other Panteras with aftermarket switches so I thought I'd share. Thanks for taking a look!
Do you have aftermarket switches in your vehicle? We do too, and we needed a good way to label all of them. We're not big fans of the plastic text labels, so we made our own iconic switch labels! There are 54 different switch icons, each pre-cut, measuring 5/8th's of an inch square. They are adhesive backed, UV resistant, printed on clear vinyl and sealed underneath an additional layer of clear vinyl for protection from the elements. Just peel and stick. Each sheet has all of the icons printed in both black and white, allowing you to label light or dark surfaces.
The labels mount on just about anything, but look best when applied to smooth surfaces. Generally speaking, the icons have about 1/8th of an inch of clear vinyl around all sides, allowing them to be trimmed to fit specific applications like the rocker switch below. Prep mounting surfaces with a clean rag and denatured alcohol for best results.
Hahahahha, awesome.
In another few weeks, we'll also have stainless steel plates that slip over common sized toggle switches. They're about 3/4 of an inch wide and 1.5 inches long, with a half inch hole drilled in it for the toggle switch. These were designed for attaching the labels to any toggle switches, no matter if there's a mounting plate or not. Will be pretty slick, and it's what I will be using in our Pantera.
Originally posted by gandalfthegray:
MacMan, do you sell the one piece gauge consel with the switch gaurds shown in these photos?
I saw this in a Pantera at the PI BBQ.
Steve
That was my Pantera. It's the same one in these photos. Smiler I would really like to design a similar, bolt on piece to sell but it's a little tricky because I no longer have a stock center console to work with anymore! lol. Shot myself in the foot. Next time I'm at PIM I'll talk to Jerry and see if he'll loan me one to develop on. Smiler
You bet! Actually, that switch IS a window switch, I just put the NOS sticker on there for the ad. You have to modify the wiring slightly, but it works fine. If you need help with the wiring, give me a shout.
You can buy the switches on ebay ($11) from 4x4 guys. You can even choose what labels and what colors you want. I think the labels that they have are pretty gaudy though. The switch itself looks good, it just needs nice looking lables like ours! Big Grin
Here's a link:
http://tinyurl.com/bg862
