I have a problem with the charging light.
When I switch on ignition the light goes on and the battery voltage is 12.8 Volt.
When I start the engine the AMP-meter shows "charging" and the voltage, measured at the battery, increases to 14.4 volt.
So far it seems ok, but the charging light is still on.
In the wiring diagram the light is connected on one side directly to the fuse #12 ( cable color white (W) and later on connected to light blue (LB) and on the other side connected to the regulator ( color: blue/black (B/BK).
In the wiring diagram I can see a 15 ohm resistor-bridge between the 2 wires (b/bk) and (W).
My question: is there anywhere a kind of switch or relais which switches off the charge indicator when the alternator is charging?
Thanks
Alfred
