I was asked to show my engine cover pictures.
These are covered 3/4" plywood. They replace both the interior hidden steel cover and the exterior vinyl covered bubble.
They sit flat on the bulkhead and are held in place by about 8 sheet metal screws.
The material is speaker cloth and the passenger seat sits all the way back against the fire wall.
Most importantly they are sound deadening, are their own firewall and largely concealed by the seat backs.
There certainly could be other shapes to arrive at for aesthetic purposes but the point is there absolutely was no reason what so ever to build the car with the original bubble with such an intrusion into the cabin.
I would state, "form follows function", leave it at that and not search further design wise...but you could play with shapes on the small raised panels I suppose but none are really focal points
When the seats are in position, the only thing that you notice is the elbow pad and the flat black material de-emphasizes the panels.
My manual parking brake assembly is also gone since it is no longer necessary with the electric parking brake that works off of the push button on the console. So a normal undeformed human can actually sit in the passenger seat.
Yes that is a roll bar also.
Images (2)
  • Dougs Pantera engine cover 1
  • Dougs Pantera engine cover 2
...alright Doug, what's going on here?? I like what you did. How the heck did you get flat panels to Clear all the Engine Pulleys? I want to do the same...removing all of the original plastic interior cover. and move both seat Backs, against the steel firewall. Did You have to move the Engine back on it's mounts? Inquiring minds want to know. Looks Great!
Marlin, if I tell you how, are you going to mill it all out of billet titanium? LOL!
You aren't going to allow WOOD SAW DUST in your shop are you?
The panels are tiered because each one needs to be to be cut around the pulleys as you step them up.
The only way I can explain that is to disassemble the thing step by step to show you what to do! OH NO! I'm trying to get the car TOGETHER, not apart!
The largest culprit is the water pump projection. I actually toyed with the idea of shortening the shaft for the pump. There what I did was have a custom pulley made which pushed back the groove as close to the pump housing as possible.
Shortening the pump shaft and pushing the pulley way back is still a good idea since the face of that pulley is about 1/4" under that plastic plug cap that you see. So the cap is the elbow saver.
Ford had reason to build the water pump that way and Detomaso was forbidden to "open or modify" the engine like that but there is no practical reason for the pump shaft to be that long in the Pantera.
You would have to remove the drive flange, shorten the shaft and repress the flange back on, then have a custom pulley made BUT you likely could eliminate that outermost "elbow pad"
There should be a "special Pantera water pump" for that reason.
The other panels are hollowed out to fit around the pulleys and belts.
What is interesting is that the plywood actually deadens the engine sounds and adds heat insulation to the cabin where none ever existed from the factory.
It also makes front engine access much easier.
Let me see how much interest there is in this and maybe if I can find that bottle of Tequilla and it will help me convince myself to disassemble it and take pictures.
It is very effective in civilizing the passenger seat space and while I agree that it isn't as aesthetically pleasing as I would like, it absolutely does work for sure.
I think it is a very good solution particularly because it is low tech and as a result not a very expensive project to do. There is nothing particularly difficlt to find with the exception of the custom water pump pulley. That was not outrageously expensive either. Maybe $100 and it came in about a week.
I did relocate the A/C pushing the mount closer to the engine, but that was simple and not rocket science at all.
Let's see, tequila, where are you? "Bottle of wine, fruit of the vine, are you gonna' let me get sober?" See, I'm starting already! Yikes. You guyz!
There actually once was a 'shorty' Ford water pump made for V-8 street rods. It's for a 351-W but can be made to fit a Cleveland without welding. It's 1-1/2" shorter, cast by wholesale supplier Buddy Bar in Southgate, CA that sand-casts up stuff like this but doesn't sell to the public. This pump is no longer sold new by Ford.  You might get lucky at a swap meet. I have one on my Fontana block.
@bosswrench posted:
The stock water pump IS the problem with creating a flat engine cover. The other pulleys are child's play by comparison.
I had only read about the low profile water pump and by the time I went to work on this project seriously, it was only a legend with no direct evidence it had ever existed.
A low profile "Cleveland" pump will absolutely fix this issue in an instant.
If you look at the pictures of my panels, the two small panels, the round one out most an the slightly larger oblong one directly beneath it, total 1-1/2" in height combined and are bridging the water pump projection.
A water pump as you say, 1-1/2" lower positively eliminates the necessity for those two and would provide a much more pleasing aesthetic solution.
I would not be shocked if someone like Randy Gillis told me that he had seen one and it existed because of the Ford Indy Racing program like the aluminum Cleveland blocks did?
The problem there is that in some cases there are only a few that were ever made and never got past the initial testing part where they could be offered to even a limited market like the "racing crowd".
If Detomaso couldn't get access to them even when needing 7,000 Cleveland engines, there "ain't no way I'm gonna' get one either?"
Although I DID come across this in a Google search.
https://www.ford.com/product/3...ter-pump-p2740727909
You have reopened this subject again Boss Wrench. Now I need to figure how this fits? Marlin? You game to see how it fits?
Ford ran off special engines for Shelby and he didn't need anywhere near 7,000 special engines built? I suppose it depends on who you know and how you are viewed at Ford?
I'm still surprised at the friction Detomaso had with Ford during this period. It makes little sense. Either you are an insider or an outsider?
Images (2)
  • Ford short alumumum water pump 1
  • Ford short alumumum water pump 2
As for the alternator sticking out into the passenger seat back area, that can be fixed two ways. The first is to cut 1.00" from the long mounting boss under the alt, and use that cut piece as a spacer between the alt and the outer part of the mbig mounting bracket. This moves the alt back with a stock length mounting bolt, and utilizes the middle pulley groove on a stock crankshaft pulley. The useless idler pulley is deleted and a shorter vee belt is needed. No other changes are required.
The second method uses the upper mounting intended for an air pump on wide-body '80s GT-5 and GT-5s engines, and also requires using the middle sheave on a stock crank pulley.  These later brackets were obviously different from the earlier brackets but bolt on perfectly.
...the solution would be to take apart a new pump, Mill the nose, shorten the shaft and rebuild it with (if) needed bearings and seals. A new Pulley would have to be Machined if It didn't already exist. Will the 351 Winsor Pump work? or you're asking me to try it out?
What are your thoughts??
That IS an interesting thought….
Milling the snout off sounds fairly straightforward, and cutting a seal seating recess….
I guess it depends on if the casting is designed to keep the water back within an inch of the face of the casting…
For a good machinist (as we have on this board), none of this is a technical challenge…  it all depends on what you find when you start milling down that casting…
Well the question is whether it is better to adapt the Ford Racing 351w pump or machine down a 351c? Any volunteers?
I have no experience either way.
With the tower on the stock water pump cut back, the water pump pulley will wind up as flat. The alternator is moved back as Boss Wrench describes as is the A/C. This is where the flat bulkhead becomes reality.
The stock 351c water pump casting actually looks like it has been extended. It is suggestive that it can be shortened some. The number that you are looking to reduce that is by around 1-1/2".
I wouldn't expect the shaft to require a bearing that is 3-1/2" deep? That part of the pump casting is very similar if not identical to the 351w pump housing which can be cut down and is available now shorten exactly 1-1/2".
The key to a flat bulkhead is a low profile water pump.
Personally, my problem with cutting down the water pump nose is reassemblig the thing. Water pumps usually use a pair of sliding discs known as a 'carbon seal' and getting them back in, with a proper press fit, without cracking them or leaving too much clearance, I've been unsuccessful. FWIW, the seals are sort of like old VW bug throwout bearings but thinner. Maybe I need instruction?
FWIW, I'm still using an ancient Weiand aluminum water pump (half the weight of an iron stocker) that I bought in the early '80s. I cracked and TIG-welded it, modified it with an impeller backplate (made no difference in cooling), and it's still on the 351-C! But I really look it over for leaks before driving any distance. Some speed parts were well made back then.
@bosswrench posted:
I haven't had the cover off in awhile. Mine is the Wieand pump and as I remember it, it only needs the shaft shortened.
I'd work on this now but it is the same issue as before. I don't want to drain the system and rebleed the thing again.
This is a 68 302 water pump housing. It has been stripped of the internals.
You may notice that the water outlet is on the passenger side. That was changed to the drivers side in 1969 and later, but other then that it is the same pump.
You can see the height of the bearing support and as I have the guts out and can measure where the bearing and seal sit internally, it is very clear that the nose can be machined down at least 1-3/4" if not a maximum of 1-7/8".
The bearing, seal, impeller locations will all remain in the same location. The "weep" hole remains untouched.
What would need to be shortened also is the output side of the shaft, and a new flat pulley made.
This indicates to me that shortening the snout on the pump is clearly doable and therefore, having a two level "flat cover" v. the four level as in my pictures is very feasible.
I don't have a mill to machine a housing down and I don't have a seperate 289-302-351w water pump to see how difficult it would be just to use an existing shorten version of them to the Cleveland?
It would seem though that it would be simplest just to cut down a Cleveland version?
Images (2)
  • 68 302 water pump 2
  • 68 302 water pump 1
With care and lots of work with a hand file etc, you can cut the housing snout off without a mill. And the Ford Racing handbook gives the desired dimensions for the housing & impeller clearances to put it back together for good water flow. The short article is concerned with adapting the Boss 302 cast curved impeller in place of pumps with straight paddle wheels, but the numbers are the same.
I am definitely going to try to do one. The immediate question is which pump to try it on.
I was thinking of using a new pump and I saw the Speedmaster is $48. That sounds like a good guinea pig to try it on since if I screw it up, it isn't a big loss?
It's tough to get any tech information of Speedmaster though before hand.
Is there anyone here with direct knowledge of it that can comment on this pump?
I agree that cutting down the nose is not a major issue. The way that the shaft is made though is going to need to be cut down in a lathe.
The exact amount to cut is also going to be experimental.
  • Speedmaster water pump 1
I won't know until I get into the nitty gritty.
I would presume that it does aligh since I have the belt on a special pulley that I had made for the water pump running now.
The intent is to cut the nose back to the point where the water pump pulley will be flat and still alighn with the crank pulley.
It does look like the dimensions work. I don't know what complications will happen within the water pump but theoretically, this works.
