Originally posted by slojoe:
happy thanksgiving fellow pantera lovers
have finally got the mechanicals sorted out but no interior guage lights and no horn. thre is a black and yellow wire in the guage pod pluggled into nothing. there is a bulb hanging from a wire up by the tach. seems like a mess. do i have to pull the dash to get at this/ size 7 1/2 hands
No, you don't have too...but...
Look for the yellow/black stripe wire near the fuse panel. Maybe it got unplugged?
Also, the dimmer switch has the habit of oxidizing after 40 years and as a result you won't get any current through it at all for the instrument lights.
You could consider bypassing it if you trace current into it but not out?
It just so happens that mine died just recently also. However, I am told, they may be rebuildable?
