...My car was plumbed w/hardware store stuff. Now, I have the updated SS and alum components. I seem to be having some trouble plumbing (test fitting) from the large cooling tubes at the bottom of the firewall in the engine compartment to the water pump and cooling tanks.... Question: I should connect the two short hard 90's ( one goes to the water pump, the other to the cooling tank) Under the car??.. I should push them through the grommets and attach them to the main cooling tubes under the car? yes?... "behind" the cooling tube brace located at the bottom of the firewall in the engine bay, under the car. Or should these two 90 deg hard lines be connect to the cooling tubes on the egine side of the brace?..There just does not seem to be enough clearence to do anything else?.. Pics if required... Thanks for any help/advice...
