I have a set of stainless brackets that move the bottom of the radiator up on top and back on the crossmember. That looks okay but I am wondering how far forward should I lay the radiator? Is there an ideal angle and can it be positioned too far forward? I have set of 12" Spal fans positioned on the back of a Fluidyne for what that is worth in this discussion. The fans will do the work in a parked position. But, going down the road is the forward leaning angle impeading airflow through the radiator and does more angle equal less airflow? What have you guys found on this subject?
Steve
I have my radiator laid at a 45 degree angle.
And yes, this will slightly hinder air flow through the core as the air is now hitting the core at an angle.
But it does allow for more core height due to the mounting angle.
You may improve the flow through the core by ensuring the radiator is shrouded around its perimeter, so all air that flows to the core must flow through the core & not escape around the radiator.
The air exiting the core I found to be an issue as the air wants to flow more upwards due to the radiator angle, than out the bottom of the car as the original design intended.
And the flow upwards is hindered by the fact that if you do have the aftermarket hood vents installed; they simply are not large enough to cater for the flow rate.
Look at the radiator core area, then the vent area, there’s a big difference.
So it means hot air pressure will build up at the back of the radiator as it try’s to exit the hood vents & has no choice but to spill out from under the car.
One would assume there must be a certain venturi effect at speed under the car as well as over the hood helping suck the hot air out.
I had an issue with the hood getting excessively hot due to the air not exiting the vents fast enough & becoming trapped.
This is in hot Australian conditions though which tends to exacerbate the issue.
Regards,
Tony.
I took a good look at everything tonight. First the brackets that move the lower mounts up and back on the crossmember are nice and allow the radiator to lay farther forward. But that cramps the back side where the hoses connect up. Also the angle seemed pretty extreme and as mentioned by Tony the fans were pointed right at the hood. I don't have vents so I thought twice about that. I repositioned the radiator to the original lower mounts and I think it will work better in my car that way. I found that a distance of about four inches c/c on the upper mounting strap holes looked good to me. Far enough for the fans to clear and not too far so hopefully the air will exit without too much trouble. I'm going to look for some aluminum angle to shroud the edges of the radiator for added benifit if any.
Thanks guys,
Steve
