I am looking for the bracket that holds the clutch slave cylinder that bolts to the trans bell housing. For some reason someone cut off the part that would hold the stop adjustment. Does anyone have an extra laying around?
marlinjackThe Machinist #5723 AMARGOSA MACHINE 'Running on Empty- Middle of Nowhere'
...'They' cut off the 'Stop' because it is Redundant and Not Needed, Because the adjusting screw NEVER touches the Stop! It Never Works! Many, including Myself, Have even removed the adjusting screw. What You DO Need is the Return Spring!...
I had no idea what I was looking for was worth more then it's wieght in GOLD! I have decided I can live just fine with the one I have so I am no longer looking to replace it. I seem to have other problems far more pressing at the moment.
Thanks cat7195! Just when I had about given up on the vendors being "resonable" with their prices, they come back to surprise me!!
