Updating the fronts without updating the rears is not recommended. It doesn't address the core problems which are (1) very poor rear brakes AND (2) a proportioning valve in the front circuit instead of the rear circuit.
No matter how strong of a front brake system you install, it will be limited by that proportioning valve in the front circuit. The proportioning valve was installed because the front rotors were unventilated and/or to better balance the front brakes with the weak rear brakes.
To upgrade the brakes you have to address the proportioning valve. The "best bang for the buck" upgrade includes:
- ventilated front rotors
- removal of the proportioning valve
- replacement rear brakes from SACC Restorations (Wilwood)
If you go with larger diameter rotors, it makes a future return to the stock 15" wheels more difficult. So if you're going to replace the brakes entirely I'd suggest going in one of two directions:
- Use 12.19" diameter rotors (the largest rotors that fit in a 15" wheel)
- Or keep all the parts you remove.
Frankly 12.19" rotors were used in Indy cars for a long time. They are more than enough for the street. Food for thought.
