I have a project in mind that requires I lower the surge tank. The overflow tank need not move for the project.
As the surge tank houses the cooling system pressure cap in our Panteras, I think the cap needs to be the highest point in the system?
With that in mind, I guess if I keep it higher than the highest points of the cylinder heads I should be okay?
What about the overflow tank? Is its relation to the height of surge tank or engine of any concern?
Your thoughts and advice are solicited.
Thanks,
