I had a headlight motor fail that made a squeal/screech sound before it finally siezed. Can you raise the headlights with the knob by hand? If not I suspect the motor. For reference my headlights well lubricated with a new motor raise by hand very easily. Before I could not raise them by hand without the knob jumping gears.
Steve
I think you can lube the bushings from the splash shields. I uses a spray can of white lithium grease with the little tube on the end for accuracy. If you have not replaced the plastic gear now is the time! Getting the headlight regulator out with the radiator in-place is not something you want to try unless you have a forward leaning setup. Even then it is a challenge.
Steve
