thumbnail [3)thumbnail [3)Crank TriggeredSystem for 351C, Includes: Trigger Wheel (see in photo), Magnetic Sensor Pic-up, Billet Aluminum Mount For Pick-up, Custom Milled to Clear timing Pointer and other 351C, Wire Lead to ECM (ECM NOT Included) some other parts...Small Bolt Spacer(s). Photos to Follow as soon as I can dig them up in the Garage. ONLY the wheel is shown in this photo. The Sensor will trigger just about Any electronic Module on the Market...but NO Guarantees! ALL other Parts were Never Mounted. Some Not-Needed Parts are Missing. See Soon to be posted photo.
$145. Shipping FREE in the USA. Ships Worldwide at Your Cost!!
Thank You,
Stable ignition timing is a necessity in performance engines. The ignition must be triggered at a precise time in relation to the position of the piston in the compression stroke. However, think of all the mechanical stretching and flexing that takes place through the timing chain, gears and cam before the distributor pickup triggers the ignition. The crankshaft on the other hand, knows exactly where each piston is, plus it is the most stable component of the engine in relation to piston position. That"s why a Crank Trigger Wheel & Sensor Kit is needed.
PCE uses a non-magnetic pickup which gets triggered by powerful magnets that are embedded in the trigger wheel. The only way to trigger the ignition is when a magnet passes the pickup. This non-magnet pickup is securely held in position by CNC machined aluminum brackets. These brackets feature a long adjustment slot providing a large range of accurate timing adjustments. Plus, many of the brackets can be used on either side of the balancer for easy installation. Most kits are supplied with several spacers for different accessories and pulley systems.
Each magnet is pressed and then riveted into the wheel to handle the fierce rpm and vibration that high horsepower engines put out. By installing the magnets in the trigger wheel, PCE has done away with the chance of false triggering. As the engine is rotating, the magnets pass the Non-Magnetic Pickup and create a signal that triggers the Ignition. The magnets are the only thing that can trigger the ignition making it the most reliable and accurate way to trigger your ignition. Magnet Crank Trigger Kits must be used with an Ignition Control Box.
MJthumbnail [3)
Images (2)
  • thumbnail (3)
  • thumbnail (3)
...Only the Crank Wheel was Mounted, and Never used as the Sensor was Never Mounted or used. The Sensor Mount was Mounted to check for Clearance and I Milled it Slightly to Clear the Timing Pointer on the 351 Cleveland. What You see is what You Get!
The Extension Cable is 6 Feet Long and Plugs Directly into any MSD Ignition 'Box', as this is a MSD Manufactured piece
$145.00 USA Shipping is FREE. Worldwide shipping is at Your Cost!
Thank You
MJthumbnail [1)thumbnail [7)
Images (2)
  • thumbnail (1)
  • thumbnail (7)
...As there are differing set-ups on Clevelands, there can be No Guarantees for the Fitment of the Sensor MOUNT. I had NO Problem Mounting the Plate on My Engine, but to Mill for Clearance of the Timing Pointer, Checked and then Removed. The Timing Wheel Will Clear the Lower Radiator Hose by 1/8th Inch!! (see in First Pic) I Never used this and the MSD-6 ECM was SOLD.
MJ
