Finished putting custom air vents into the Pantera's new carbon fiber hood. The hood is super nice and fits great. It came without vents, and that actually worked out nicely because we didn't want to install the traditional Pantera hood vents. We wanted something with more shape, made from a more modern material. And since we're running the radiator in the laid down position, we were able to make the vents taller to help vent more hot air.
First I had to come up with the design. I designed the vents to mimic the shape of the gap between the back of the radiator and the front of the trunk. Had to leave room for the hood support beams on the sides and in the center. I rounded the corners using a small paint can cap, and adjusted the front most line to have the same curve as the front of the hood (instead of the straight line of the radiator). Jaime found the steel mesh material from an on-line computer store. Comes in flat sheets. Once we had the design and metal mesh, we needed a way to shape the mesh. Made a trip to Low's for a couple planks of wood and some router bits. Traced the pattern onto the wood and made a positive and negative shape for each vent. Inserted the mesh, fit the wood pieces together and clamped them down, pressing the mesh into the proper shape. Primed and painted the vents semi-gloss black with rattle cans.
Next, I traced the design onto the back side of the hood so that I could see the vent position relative to the hood supports. Remember how I used a small plastic cap as a guide to draw the rounded corners of the vents? I used the same caps to draw a full circle at each corner, marked the center of each circle, and drilled a small hole through the hood at each mark. These were used as registration marks so I could then transfer the vent pattern to the front side of the hood. I used a metal cutting disk on the dremel and cut from the front side of the hood to make sure that all of the lines were perfect. This is the most carefully I've ever cut anything! All the lines came out perfect. Once the holes were cut, I hand sanded the edges and test fit both vents.
Now it was time to finish off the newly cut edge. Using 1/4" pin striping tape, I followed around each vent hole to make a guide line. Then I outlined the guide tape with a second piece of tape, and removed the original guide line tape. This gave me a perfect 1/4" piece of exposed carbon fiber around each vent hole. Jaime finished masking off the rest of the hood and I scuffed the carbon fiber resin lightly to help the new paint stick. This time I painted with glossy black. Once the paint was dry I installed each vent using a bead of black silicone sealant on the back side of the hood.
Once the silicone was dried we re-installed the hood. Pardon the dust on the rest of the car. We're getting there, one piece at a time!
Thanks!!! I'm so excited about how nice it came out. I was nervous about cutting into the hood, not having done it before, so it's a big relief that all is well. Glad you all like it. Smiler
Not sure about the weight of the hood. This is one of the Wilkinson hoods, very similar to the PIM hoods. It's carbon fiber over fiber glass. A lot lighter than stock, but not as light as a full CF hood would be. Works for me though. Less weight is still good and it feels very solid. Sure looks great.
Fit of the hood is very good. Bolt holes lined up perfectly, etc. Only thing I had to do was make the latch a little shorter. It hit the weatherstripping until I trimmed 1/2" off of it, but that only took a couple seconds with a dremel.
Will try to sell the steel hood. Thought about seeing if any of the vendors wanted to buy it off of me for cheap. It's in perfect shape. I wouldn't mind storing it away, but we'll be moving soon hopefully. I've got a whole bunch of car parts that really need to go now.
Originally posted by MacMan:
mccall, the only thing I'd be worried about is shipping it. any ideas?
I will take a picture of the underside of the new hood in the morning.
Wasn't planning on running any ducting to the openings. Most important thing for me was to be able to vent out the hot air. Would ducting help that?
Just wondering.
The more I look at your vents the neater I think they look. Cool
Now I'm torn, old hood with lots of body work to be done or cool looking CF hood..... Roll Eyes
Thanks so much for the kind words!
Some more pictures. I still need to either paint, or make covers for the inside of the hood where it's still white. Black paint would work just fine, that's what I did where the vents are. I also thought about making some nice alcantara covered pieces to fit in there. Not sure which way I'll go yet.
One of my favorite things about the new vents is that you can see through it when the hood is closed, and see the headlight bar, Fluidyne Radiator and Flex-a-lite fans in there. Looks very cool. Tried to take a couple pictures of it.
Back side of the vents doesn't look half bad, despite the super simplistic way of attaching them.
Posted by rmccall:
Couldn't you make up a simple wooden crate and ship the hood UPS??
This is exactly how Kirk @ Amerisport shipped me an OEM hood earlier this year for front end damage to my car sustained late last year. Came through perfect & I ended up shipping my buckled hood back to him for credit in the same crate. Simple 2X4 frame with 1/4" masonite top & bottom. FWIW.
The hood scoops on this Brazilian Pantera are almost identical to yours? Were they inspiration for your vents, or just a funny coincidence? Regardless, your vents are very cool.
http://www.garagemdobellote.com.br/2008/09/de-tomaso-pa...a-recordista-de.html
Again, thanks for sharing your process on the PI Board. Very clever how you made the forms out of wood to shape the steel mesh.
Not so much of a coincidence I think. I haven't seen the car before, but when drawing the shape of the vents, I tried to make them as large as possible. If you fill the space between the radiator and trunk, that's the shape you get. He must have gone through the same process.
Nice looking car too.
Good eye for noticing it! Thanks for sharing. Big Grin
