For Jack or others...
I just saw one of Carroll Shelby's "Sidewinder" intakes for a 427. This was a dual plane with big runners and had a "notch" cut in the plenum divider between the two primary throttle plates only that was about 1/2" deep.
What is the advantage or disadvantage of this modification? The manifold was supposedly setup for high end operation.
I think this is supposed to improve mixture distribution at mid and top-end, by allowing a little 'cross-pulsing' of the intakes between the two plenums. It was most often used on open plenum intakes in the 60 & 70s, to tune the primaries & secondaries with a big Holley, and I'm doubtful as to how much it actually helps on a street engine. Is this a new intake or a replica?
FWIW, Rodger, I modified an open-plenum 351C intake for a friend, by milling 2 small notches in the carb pad for an 0.060" thick removeable divider plate that hung down about half-way in the plenum & was retained by the carb on top of it. Since the engine dynoed at over 450 horses, I don't know how effective it was. Hise Pantera was scary-fast every time I drove it, with or without the divider. But the intake pulses that reflect back into the plenum soon BROKE the divider, whch ended up jammed into an intake port! Forunately, it didn't quite get into the seat area, but if you build something to insert in an intake, I suggest you make it substantial and weld it
