In a nut shell, are all three wire narrow-band oxygen sensors basically the same from an electrical signal basis?
I have a Halmeter AF/30 air-fuel meter on 2511. It is using the supplied Bosch 3-wire narrow band sensor. Common ground for heater and Lambda signal.
I also have, in a box, a first-generation ANALOG Holley Projection 4 TBI fuel injection unit. Came with 2511 and I'm moving towards installing it next winter.
This can be upgraded with a 3-wire, Holley narrow-band-based O2 kit to provide better closed-loop AF monitoring in low/mid ranges.
There is one of these upgrade kits on eBay, but it is minus the O2 sensor.
Should the Halmeter 3-wire sensor work for the Holley kit?
