Does anyone know where physically the pink wires that tie into the load side of the ammeter are located. None of the wiring diagrams that I have seen show this.
marlinjackThe Machinist #5723 AMARGOSA MACHINE 'Running on Empty- Middle of Nowhere'
...The 4 Pink Hot wires are located with-in the wire Bundle running the length of the dash (Backside). They can be found by following the Black 10 gage wire the comes off the Amp Guage and connects to them at two different places...
Thanks for the info. I'm not going to "chase" them as it is a lot of work just to actually find the connection. I'm going to do the Mike Drew mod so hopefully these overloaded circuits won't run so hot and the voltage at the fan motors should be more than 10.5v Steve
