Hello
Any advice for the "best" camshaft you would use ?
- 351c engine
- 4V quench heads
- single plane Holley Strip Dominator
- 180 headers
- track car (3000-6500 rpm)
Thanks
Philippe
quote:Originally posted by "72 GTS:
Doug,
thanks for the advice (to George too !)
That's a good american engine sound !
here's what I have right now (new in box).
http://www.compperformancegrou...egory_Code=F351MFTCM
I was told something like 400HP with a good carburator and exhaust ...
what do you think ?
It will not be a street car, I need power from 3000 to 6500.
kind regards
Philippe
Doug,
kind regards
Philippe
quote:Originally posted by Dave2811:
Here is CompCams online Camquest program. You can fiddle with all kinds of parameters to determine what is right for you.
http://www.camquest.com/
quote:Originally posted by PanteraDoug:quote:Originally posted by "72 GTS:
Doug,
kind regards
Philippe
It's a sound Ferrari hates with a passion. It's so...so...American?
quote:Originally posted by PanteraDoug:quote:Originally posted by Dave2811:
You can only do it once per registration. You need to keep registering.
quote:Originally posted by George P:
Here's a spec for a custom ground cam from Bullet Cams. Its a tidy little cam with a wide flat torque curve to complement the 4V heads and road racing. With a good exhaust system it should make good use of the Holley intake manifolds top end capability while still retaining some low rpm torque for accelerating out of corners.
Camshaft Spec:
Grinder: Bullet Racing Cams of Olive Branch, Mississippi
Telephone (662) 893-5670
Engine: Ford 351 Cleveland, 4V cylinder heads
Solid flat tappet camshaft
Intake Lobe: #FF280/371 (CRA, designed for Ford 0.875 tappets)
Intake lobe mathematic centerline = 110° ATDC
Exhaust Lobe: #F292/373 (CRA)
Exhaust lobe mathematic centerline = 114° BTDC
112° lobe separation angle (camshaft degrees)
Exhaust valve opening = 80° BBDC
Intake valve opening = 30° BTDC
62° overlap
Exhaust valve closing = 32° ATDC
Intake valve closing = 70° ABDC
280° advertised intake lobe duration
251° intake lobe duration at 0.050"
Intake lobe major intensity = 86
0.620" net intake valve lift (1.73 rocker ratio, 0.022” lash)
292° advertised exhaust lobe duration
263° exhaust lobe duration at 0.050"
Exhaust lobe major intensity = 94
0.630" net exhaust valve lift (1.73 rocker ratio, 0.019” lash)
Request to have the custom ground flat tappet cam nitrided (surface hardened) and polished for the best possible durability.
-G
quote:would stock vavles be long enough?
Hello Doug; Appreciate you supplying the specs & real LIFE driving experience/characteristics of the cam you are using.quote:Originally posted by PanteraDoug:
It depends on what you want the nature of the car to be.
Although mine is a street car I find this one nice for what I want. I would say that if you needed to drive the car to work and the grocery store daily (if you eat a lot) it is too much.
No worse then a motorcycle though.
It is border line for the Webers, but Webers are borderline lifestyle anyway?
It could be a very nice track cam. Numbers are all around where they should be to maximize the heads, exhaust and induction.
Camshafts are very personal and everyone will have their own opinion.
I like it, but I use the car differently then most.
http://www.compcams.com/Compan...s.aspx?csid=861&sb=2
http://www.compcams.com/Base/M...ytes/CompCams292.mp3
If you walk within 20 feet of the exhaust it will knock your cap off of your head because of the exhaust pulse.
The only other car that ever did that to me was one of the Shelby American, former, GT40 team cars.
Some will say that it is "one step over the line" but if you aren't living on or near the edge you aren't maximizing your life. I've been over the line for most of mine.
As Paul Simon once observed, "when something goes wrong, I'm the first to admit it, the first to admit it BUT the last one to know,
When something goes right, it's apt to confuse me, because it's such an unusual sight?"
Your mileage may vary.
quote:Originally posted by 1Rocketship:Hello Doug; Appreciate you supplying the specs & real LIFE driving experience/characteristics of the cam you are using.quote:Originally posted by PanteraDoug:
Seems to check ALL the boxes I'm looking for.
The specs list it as a 6,500 rpm cam.
In your experience you have no problem revving to 7,500 rpms, am I correct in this statement?
Also, Is that cam available in a solid roller lifter application?...Thanks!...Mark
Originally posted by ilyes:
Would you run longer valves or stock length should be ok? If I were to run beehive spring for that cam, and need to achieve 1,900 of assembled height, would stock vavles be long enough?
Hello
- 351c engine
- 4V quench heads
- 180 headers
Thanks
Philippe
