The console is in there (stock) with a whole bunch of screws into the floor, as well as being pinched by the rear section (package tray) and the gauge console & main dashboard. You cannot pull it without more trouble than you ever thought possible....and once off, you find a welded steel inner console underneath that is a structural part of the body. But the radio can be accessed well enough for wiring, etc through the passengers' inner kick-panel under the dash.
