I recently acquired a Pantera radiator that had been "re-built" and it was recommended (thanks Mike) that I have it pressure tested before I replaced my Dec. '72 stocker with it. A wire inserted into the right lower drain touches the front of the tank as per the early/late baffle check.
My radiator shop mechanic quickly identified it as having been re-cored, and when filling it from the upper pipe in the pictured position water flows directly out of the bottom pipe when the water reaches the line indicated.
Testing went no farther as he then indicated that it's now a useless radiator.
Any ideas as to what's happened here?........
