Ray,
Perhaps you should clarify. Do you just need the steel plate that mounts to the car and then has the license plate mount to it?
Or are you seeking the license plate light unit?
You can probably do without the steel plate and just mount the license plate with an aftermarket unit/frame to the upper two threaded bosses in the car. Or make your own. It is basically just a flat piece of steel with some holes.
