I run 50/50 anti-freeze mix in my California car. A friend advised that he runs pure anti-freeze to avoid the water/rust problem and has no problems with it. Which is best?
strait water disipates heat faster and more efficently, but i only recomend that in a drag car but 25 percent sound good. a proper 50-50 mix is also good for a apx 5-10 degrees f over boil protection
