'71-73s have u-shaped steel brackets that bear against the body, and the 'gill' has 3 studs that pass thru the brackets with nuts and lock washers. Depending on your year of car, the gills may come off easily or be glued in by decades of paint. In any case, the right side is more accessible than the left, the nuts etc being behind the fuel tank body shield.
My 73 has nuts …… easy to remove……… do not over tighten
(insert joke here) roll on floor
OK, I can’t stand it anymore,,,,
Be very careful when handling the nuts as you will be in a compromising position. Penetrating fluid should help to get them off nicely; additionally it will help prevent galling of the surrounding areas. Once you get a nut off, do not let go of them as they may drop & hit you in the chin or god forbid go in your mouth, choking on nuts can be very embarrassing, especially if the neighbor is watching. If for some reason nut ends up in your mouth,,, whatever you do.... do NOT swallow it, spit it out! When the time cum's, you might want to employ safety glass’s, rubber gloves and/or have a towel and some good cleaner ready for any excess fluid that may have splattered. Please let us know how it comes out. Take some pictures & Good Luck.
roll on floor
Merry X-mas
Originally posted by 4NHOTROD:
Take a look up in the wheelwell area to see if you have nuts (insert joke here) or if it's push-on type. Either way, spray some penatrating fluid on there for a day or so.
Will
