My Pantera did not come with any seat belts and I couldn't find any pics of seatbelts anywhere on the forum. I am trying to figure out if i should be looking for a set of retractable or stationary belts. The hole size (2 1/2"x3/4") above the rocker seems quite small to get a retract down in there. Any advice would be great.
Thanks, Toby
Mine came with I believe std twin retractables.
I have replaced them with std retractables and they fit and work fine.
also that part on the rocker sill is screwed on with 4 large phillips heads screws. remove them and you can get to the back of it.
they will be tight, use a big screwdriver and lots of force, be carefull you don't round the heads otherwise you will be upset !!
