I needed to replace my rollers on my seat tracks so I decided to give one of our suppliers some money for what I thought was going to be a superior product than the original wheels. If you never looked at them the original rollers are a hard round rubber compound sandwiched between to side disc's and pressed together onto a solid dowel. The side disc's allowed for about 1/4" of rubber to be exposed and eventually flatten out so they slid rather than rolled.
So for $80 what do you get?
A solid brass (?) dowel was cut into 8 pieces and maybe slightly beveled at the edges. Thats it.
I was expecting something a little more complicated or maybe a piece of rubber someplace, maybe a roller barring or something but the darn thing wasn't even the same diameter as the original "wheels". Maybe these were the optional "lower your seat" model. They work, I even thought about doing something similar since I'm the only driver and the seats only get moved to get to the front of the motor. I learned something on this one.
Steve
Steve,
Those are a set of nasty originals that I restored.
One side was bent and took a lot of tweaking to get it to work properly.
After I machined the rollers I assembled everything and kept bending it until it rolled smooth. The other side was fine.
Then I took them back apart and sent all the parts to the Zinc platers. I had the handles re chromed and bought new knobs from Hall.
They turned out nice.
The only problem I had is the rollers are slightly shorter than the rubber ones and wanted to fall out easily until I assembled the stop bracket.
Here are both of them done.
  • 121905_056rs
An update on the wonder wheels.
I installed them in the passanger seat tracks and they seem to work fine with one small issue. When I excellerate or come to a stop the wheels sound like a set of ball barrings rolling around under the seat. Seems they roll around to good with no load on the seat. I figure there must be an adjustment to be made to the track or a washer added to the bottom to get the rails to squease all 4 rollers so they don't free roll. Maybe some grease would slow them down. Go figure....
Steve
Seems they roll around too good with no load on the seat
Yup, you are not the first to find this problem. I think one owner solved this by drilling a hole through the center of the rollers and placing an appropriate spring in that hole, one that would drag on the seat rails, but not prevent the roller from rolling.
