factory cast iron heads with tapered spark plug seats?
.055" is more gap than the suggested plugs are designed for, by a lot. the ground strap will not be parallel to the center electrode causing rapid wear and short plug life. the gap will not hold at .055" for long at all, but will increase as the electrodes wear.
RV15YC4 is designed to gap at .039" https://www.sparkplugs.com/product.aspx?zpid=8446
RV15YC6 is designed to gap at .059" https://www.sparkplugs.com/product.aspx?zpid=8576
but be careful these are extended projection tip plugs and may reach the piston?
how are you at reverse engineering? https://www.sparkplugs.com/Search.aspx?ptn=Spark+Plug
...The Experts with Thousands of Pages of Dyno Results and Research, have Documented..."There is NO evidence of Any Power Increases with Any Spark Plug Gap Larger than .050"."
I have found that to be true, So I Gap My Plugs to .045". So as they 'Wear-In', they Come Into Tolerance , rather than Out of Tolerance.
I have tried/experimented with the Champian Plugs in the 351C. They worked well in My 400 Pontiac, But NOT so great in the Cleveland.
I have found the AUTOLITE or AC plug works as Expected. I tried All Heat Ranges 24, 25 and the 26. My results are, just like
Goldy-Locks, 24=Too Cold. 26=Too HOT and with Increased Pinging! 25=Just Right! So Now You've Heard it From 'The Horses' Mouth'! NO BS, NO Theory, just Years of Road Tests.
MJ
