"...You pay Peanuts, You end up hiring a Bunch of Monkeys!"
OR Wasting Your Money on Junk, that in Time, will Only Fail! Usually, in a Short Time.
This is What Your looking for.
Made in USA by 'Taylor', I believe. Designed to Handle 200 Amps. Another Theft Deterrent!
Do I need to Explain WHY We Switch the GROUND Cable, and NOT the POSITIVE Cable??
Last, To Anyone here, whom has had trouble with their Battery, I recommend a Trickle Charger. You'll think a Miracle has Happened! Especially in the Summer Heat in a Garage. Heat Drains and Destroys Batteries. And the worst thing You can do, is Leave a Battery Discharged. OR, Not Charging, Not Charged for any Period of Time. The Trickle Charger will Also, keep the Plates Clean, from 'Sulfating', and Make the Battery Last Longer, and Help Protect it from a 'Premature' Death.
And, What we all Love, when you go to start that Pantera, after a few Weeks/Months of Rest, You'll receive That Wonderful 'ZING' To Life! I have measured the Volts after Disconnecting the Charger, the Maintained Voltage Is Actually Higher than the Alternator can Leave in the Battery, after a Long Highway Drive! No Worries about Over-Charging, the Charger shuts down when the Battery is Optimum, and Maintains It.
