> I recently came across an (nos) set of (sterling) dome pistons at my local
> parts shop, the part nr. is gone, on the box, 302 clevor they are 4.000",
> i compard them to my clevland pistons, they look the same. anybody nows
> anything about these pistons? will they fit the 351c?
They are likely Sterling part number H557P cast aluminum pistons meant for
a 302 running 2V Cleveland heads (yields 9.0:1 compression ratio with 76.2cc
open chamber heads) and 302 rods. They would have a small dome with canted
valve reliefs. I don't have the pin height handy but could back it out
from the rod length, stroke, and deck but I think you'll find it won't work
in a 351C with a stock length rod.
Dan Jones
