The stock camshaft is available new from aftermarket suppliers such as Melling and Speed Pro.
Due to the production tolerances no two blocks have all 16 tappet bores oriented in the exact same angles or locations. Therefore when a used camshaft is installed in an engine block other than the one it was originally installed in, it is probable that one or more lobes will wear at an accelerated rate.
