Is somebody pulling my leg or can this be done?
An acquaintance claims that he syncronized his webbers by floating the balls above the stacks. It sounds plausible but what do I know.
quote:Originally posted by George P:
1976 Ferrari Boxer (512 BB) production car, flat 12 powered
quote:Originally posted by PanteraDoug:
You don't/can't sync the reversion only balancing the air flow by controlling throttle openings.
What happens though is that you can only sync 4 of the throats. One from each carb.
You use the higher of the two of each carb so essentially you are getting the engine to idle on 4 throats.
