This is just weird !!  Does anybody know what would cause this? Engine running. Fans on. IR gun says 192 at the tank. I was putting the screw back in the gauge panel and when I moved the screwdriver past the front of the gauge I noticed it moved so I took this video.
Thanks in advance for any ideas.
Doug M
Videos (1)
IMG_1898.mov
Thanks Rocky,   That has to be the reason. I'm pretty sure the screwdriver is not magnetic but I'll check it. Had the car out last night and was running hotter than usual. It's almost always an electrical problem so I pulled the gauge panel and checked all the connections.  I'll get it back out in the next day or so and see if I made any difference.  With no screwdriver anywhere near it.
Thanks again
