How cool are these? This weekend I installed front LED turn signals from Pantera Electronics. These things are bright! In the first pic you can see the new LED panel installed into the original Pantera housing. This is an awesome install. Much easier than I expected. No modifications are made to the factory housing, just open it up and insert the LED's. Run the wires through and put connectors on them. They plug right into the factory harness. The only other thing left to do is install an electronic signal flasher. Pantera Electronics also makes a nifty flasher so I bought that too. It has a Green LED that lights up letting you know that the flasher has power and is operating correctly, plus it makes an electronic "di-doo" flasher sound. It is quite loud, could be great if you have trouble hearing your factory unit. It was a little too loud for me though, so I put a little strip of foam tape over the speaker hole and now it's perfect! Did I mention that these are bright?
