I use Titan Valves and verry light komponents on my Yates Headed 351c .
My Question is : Can I lower the valve seat preassure ?
I run a Lunati Roller Cam.
106 lobe
.668 lift
265 276 @50
Jessel rockers 1.9 ratio
The suggestet valve seat preassure is 230 Lbs.
On my flat tappet engine with nearly the same lift, I have only 130 Lbs seat preassure.
Thanks for your help!
