I haven't checked yet but I need to repair a coolant hose and would like to know where I should drain the coolant and how much to expect.I suspect there may be a drain cock under the radiator but thought I'd check the forum 1st. If I just remove the short hose going to the block, will I need to drain the system? Thanks, Randy #2472
