markcharltonOld enough to know better and still young enough not to care. My '71 Pantera
David,
As noted, the Taurus motors work great. I did this mod and am just your average level mechanical ability. I detailed the process on my site. You can see the steps involved. It is easy to do on a weekend in one day.
I also have done the Taurus conversion on two Panteras and had no issues. While doing the conversion I also modified both cars so that the windows would roll all the way down since I already had everything open.
I found 4 vans this summer at a recycling yard. By the time I got back with tools 2 were gone. I found some references saying that all the motors from 89-93 had the same part number. This was not the case for myself. The 3 bolts start with F19B(93) and the 4 bolts start with F09B(90). I don't know the trick to finding them. Guess it's all a mater of timing. I think with all the new metal working skills I had to get to work on my new car I would be able to make the 3 bolt ones work. It may take duct tape and bailing wire, but I'd get it to work. Good luck.
ok so i had the same issue te recycling yards here have shipped most old sheet metal to china so slim pickins i wanted to not cut my window metal but took the plunge easilu found 2 taurus (or sable) rear window motors easy removal (tip take the plastic wiring connectors, makes hookup easier) very average mechanical skills in fact below average followed excellent instructions on pantera place website result a pleasant sqaturday afternooon and windows work great
