@jmardy posted:
Seems like this should be a switched thing. Why would you want it running with the key off?
Or is something wrong with mine?
I have this same issue.  And I've verified with Jon Haas that all the wires on the PE Fuse Panel are correct.
So, jmardy, what wire did you move from what position to what position.  I'd like to double check mine.
