Push in the little hole on the side all the way through with a small screw driver and AT THE SAME TIME place a trim removal tool underneath the knob plastic knob and pry it up. Place a towel under the tool to protect your vinyl. The trim removal like the one below will give you the leverage. Spray a little WD40 into the knob will also help release years of buildup inside, that's why it hard to take off.
