Anyone have the diagrams for a 79 GTS specifically at the Relays and 16 position Fuse box .. I have some wires disconnected .. by the relays a red/blk, green /blk and a white .. near the fuse box a large yellow /blk. I think they have some think to do with horn and key buzzers ..but the colors are different from the Std diagramms.
Thanks in Advance.
Ron
Attached is a scan of PI's parts book. It shows a relay for the central looking , not sure what side of the car it would live on, #58. If you have the wiring for the acuator in the door, you will have at least 2, most likely 4 more wires than you need for the windows and lamp, including the speaker wires if they are mounted there.
It also says there is a relay for the driving lamps in 1985. Mine does not have one, yet.
I do have fog lamps front and rear, hrw, 16-way fuse panel plus headlamp washer pump and jets.
It was going to Sweden I believe.
You might try pinging GT5-9189 who is posting pictures of his car in that section. He has the wiring attached in 2 pictures.
  • scan0003
Your not going to believe it but the other night after testing the defrost switch ..it had no power to it...then I took a cruize to the BEAR Mountain cruzie night and on my way back I tried the switch and it lit up red ... I think cleaning up the wiring and pulling out the old amp, radio , fan overrides and the rear fog light .. and plugging in the disconencted wires ..things are staring to turn on ... next is the interior light in the dash board .. I think I just figured out what the lonly yellow . blk wire is going ?
Thanks
