I am in need of a couple of poly rear sway bar bushings, stock bar size. Specifically, the center bushings, if that makes a difference. Thanks for looking!
Sorry Dave- I don't closely monitor the PI Forum so I missed this. Know that JC Whitney sells poly bushings in several sizes for $9.95 a pair. They're red plastic if that matters. I've run them for a decade and they work well & last!
