Hi. Before I pick one up online, curious if anybody has a Lecarra wheel (Mark 4 it's called) and hub laying around...? Thanks.
2511 has that wheel and I have no complaints with it. It was mounted by Dennis Quella and incorporates a Grant removable/lockable hub. That lockable hub offers great security when parking away from your home garage, and a removable wheel is a godsend whenever you need to do under the dashboard tasks.
if that approach interests you just ask and I will provide the necessary information.
The nine bolt style is not very common, perhaps this information may help you find simple adapters if you choose to go that route.
Thanks, and yes please send me that info. I was able to find the wheel and hub (it says for Panteras) on Jegs too if all else fails.
The removable/lockable unit is available from Summit and Jegs and costs about $150. Grant # 2001. Unfortunately, it requires a now out of date grant hub adapter, # 3295.
I currently have one spare Grant adapter that I will sell to you for $75 plus shipping at my cost.
with this adapter the installation is a very simple bolt on project.
So just to be clear, this Grant adapter works with a Lecarra wheel, but in order to install on my Pantera, I need both hub and adapter... is that correct?
Jegs lists their Lecarra-to-Pantera adapter for $85 and the Lecarra wheel for $170. So the two Grant adapter/hub setup is because it's removable and lockable, right? Sorry if I'm not getting it all... it's friday and my brain is mush!
My last post was a bit premature but let me hopefully get everything clear this time.
The basic Grant bolt pattern is a three bolt design. There are multiple adapters to allow five, six or nine hole wheels to be mounted
you will need the removable/lockable kit, Grant #2001.
you will need the Grant adapter #3295 that I can sell to you. This adapter mates to the Pantera/Capri spline shaft and provides the three holes to mount the always-attached-to-the-shaft lock portion of the kit.
UPDATE: 10/2022 - The obsolete grant adapter is now being produced by a Capri specialist vendor, TeamBlitz.com Your contact person will be Norm, emails are very promptly answered and I’ve spoken with him several times on the phone. He knows the adapter is good for Panteras and he will be happy to help you with assembling a complete package. He has already put together several packages for Pantera owners, and can even provide the grant security quick-release which is removable/lockable.
The removable portion of the lock kit, always attached to the steering wheel, only accepts steering wheels with the three hole Grant steering wheel pattern
You will thus need to adapt that three hole pattern to a 9 hole pattern.
on 2511 this was accomplished using two adapters. A three hole to 5 hole adapter, and then a 5 hole to 9 hole adapter. The 3 to 5/6 adapters are readily available and come in various thicknesses. On 2511 this adapter is 1 inch thick.
My search just now actually found something I have not located previously, a direct 3 hole to 9 hole adapter
you will need a nine hole trim plate.
you will need a center “horn” button
I think this clearly covers the steps needed to adapt the security/removable kit to a Pantera.
Thanks! This is super helpful.
