I need help and guidance on this one.
When I turn on my headlamps my fuel and oil pressure gauges get pegged at the top of the dial.
Other then the entire friggin' I-talian wirin harness any ideas where to start to look?
Just in case anyone thinks I'm having fun...well I'm not.
I wanna shoot myself but I already tried that and missed. Now there is a bullet hole through the roof that leaks right on me everytime it rains.
PanteraDoug, i had the same problem on the POCA trip to Las Vegas but without my headlights on. Check the wire to your oil sending unit, clean the post and make sure the wire clip is secure to the unit. That or you need a new oil sending unit. There are three wires that attach to your fuel sending unit located on top of the fuel tank on the drivers side. Easy access is through the engine compartment. Clean those wire clips and posts and reattach securely. Both were easy fixes and worked for me. Chuck
