Hi Team, an other small one.. the bulb in the Hazard Switch is boken, well INDICATOR does not flash. How do I get it out. I tried push and twist etc..but it does not move. Befor I break anything..any experience .. TX
Matthias - yes it pulls out easy. Same type base as most instrument bulbs, but smaller. Print on the bulb says "PH.12/1.2" I assume this means 12V, 1.2W. Here is a photo, next to an instrument bulb for size:
