To get the old belt off and the new on I have to move the idler. How do I do that? From front to rear I can see:
19mm nut
Idler wheel
17mm "nut", flat on 2 opposing sides, round otherwise
Bracket
19mm nut
I've loosened the front 19mm nut, doesn't help.
I've tried loosening the rear 19mm nut, bit difficult to get to, but with a proper socket and extension I got hold of it from beneath the car. But I can't get it loose, even with using my whole weight for momentum.
How do I get the idler loose Confused
