How the heck do you get to the front bumper bolts on a '74L?
quote:Originally posted by fordgt:
if you don't have caps and you see sheet metal screws than you probably do have an aftermarket bumber. What is it made of? the original bumper was a flexible rubber piece over a plate of steel. problem was moisture got between the rubber and the steel and the steel rotted away. If you have an aftermarket bumber they are usually painted rigid fiberglass. The dealers sometimes leave it up to the customer to figure out how they attach to the car. We used "lag" screws into "lag" shields epoxied into the bumper . We used large fender washers and used the holes that the original bumper mounts passed through.
It may help to remove the inner shield and remove one of the headlight assemblies and you should be able to see and access the bumper.
gary #06984
quote:It also seems the headlight buckets are in the way of the bolts.
quote:With the headlights partially up there should be enough "wiggle" room to get your hand into the front of the headlight opening and get at them
