Originally posted by No Quarter:
I'm a bit confused on this matter of how tires age, because I just had two very different experiences. When I got my Pantera home from California with Michelin Pilots, it was sliding all over the place if even a drop of rain on the road. I got new tires, exact same brand, and now it sticks to the road very well. So aged tires are useless, right? But last month I bought winter wheels for my Cadillac STS, they had been stored at the dealer since 2007 with new (then) winter tires. I bought them really cheap, because both the sales guy and me agreed that winter tires 7 years old would be useless, I would have to buy new ones. I put them on just to test, and they're fine! So age is perhaps not a problem if kept in nice storage and never gotten hot/cold/hot/cold...?
Two things to mention here that I have experienced and could be something that you are also. 1) you can not put any kind of tire/rubber treatment on the tires, i.e., Armorall. All it will do is permanently "grease" the tire. It will modify the coefficient of friction of the rubber permanently and just make the treads slick.
2) "summer" tires also refer to the operating temperatures of the ROAD and the tread rubber compound. Tires made for use under "summer" conditions are made for PHOENIX ARIZONA at the height of the summer operating temperatures.
Try about 135 F AIR TEMPS. God knows what kind of road surface temps?
That compound formula will loose it's grip somewhere around 40 degrees F. Under that the tire will slide around like it is on ice.
If you are going to drive the car in cold temps (northern Europe winter) you need WINTER tire just for the tread compound formula alone.
A summer compound is just not going to get hot enough to work.
This situation is just exasperated by the size of the tire contact area and the load on the tire.
I learned here centuries ago, that if you want to live through the winter and drive ANY car you have to put the skinny tires on the car.
These are my experiences here in NY. The winter road conditions here CAN resemble those of Northern European winters.
