Got home friday evening with my new aluminum radiator and found I need an air bleed fitting and a drain fitting. I'm assuming standard pipe threads and that they should be stainless steel since you shouldn't use brase/copper on aluminum right? Where would you look for them on a saturday? Home Depot?
