Could anyone email me the article on modifying to tapered roller bearings on rear uprights. (August 98 issue cntinued??) Was there a previous issue. THANKS THANKS THANKS KEN kfedirko@heliqwest.com
No previous- there was a subsequent article in June '99 called, "Taperd rollers- a 3000 mile update". FYI, almost all back issues of the POCA newsletter are available from the POCA Store in Spokane, WA, quite reasonably. E-mail {asajay@asajay.com}, the Store manager
before you commit to a solution, shoot an email to jb@jhpmotorsports.com he has a bearing conversion that does a better job than just replacing the stock bearings
he has a 4 roller bearing system for the rear axle that distributes the load accross the entire axle stub.
cool stuff
he also has a modification for the stock suspension that allows you to use newer cheaper ball joints.....
