HAve leak, flow and pressure tested radiator. All OK. Supply tank pressure tested and releases at 15 lbs. Replaced thermostat as engine rebuilder had incorect one in. Have gone for Jacks idea of the 5/8th frost plug in the bipass, as having trouble here in NZ getting correct one. jacked up both front and rear in vering orders to bleed air out of rad and supply tank.
THE TROUBLE STARTS when the thermostat opens steam and a bit of water come out of supply cap. temp gauge reads about 160 170
then the fog appears. temp sender in block .
Q. Is this just more air purging and the cap cant handle the extra pressure and the water can,t escape to the expantion tank fast enough.Or do I have bigger troubles. As a side the water in the rad is bearly warm at this stage.
Jack if u could Email me at CKW@xtra.co.nz, I'd appreciate it I would like to talk to some one in the no on the phone if this was at all ok with you.
Thanks
cheers cj
