Dunno- it depends on the master cylinder you're using & how much vacuum your engine develops, the tire size & composition, the size of calipers and rotors (stock or aftermarket), brake pad mfgr, the balence of the car....A host of things are changed on each owners Pantera, and these plus maybe a few others affect brake balence. The drill is, you add a manually adjustable proportioning valve to the car, then find a deserted stretch of road and two friends. You broom off the road in one area so its nice 'n clean, then get a short run up to maybe 50 mph and stand on the brakes. Your friends are standing alongside each edge of the road & report on which if any tires locked up. You change the bias a little & repeat until all 4 act the same. Takes an hour or so.
