If the thermostat is wide open & the coolant temp is climbing, you have a problem! In that case, a 160 degree thermostat is NOT a cure. Sure, the thermostat will go wide open sooner, but the heat removal capacity of the system remains the same, and the temp will still climb under the same circumstances. Removing the thermostat all together will remove a restriction and thereby improve coolant flow a bit, but a lower temp thermostat does not help remove one additional btu from the coolant.
In a properly operating cooling system, the thermostat most certainly does control the temperature of the coolant. Like the oem system in my Pantera, which regulates temp most happily at 192 degrees F. I fully agree the system is marginal. I'm not happy with the marginal performance and shall fix the shortcomings very soon. And share the whole process with the bulletin board.
We should avoid turning this into a "Gary Hall & Dennis Quella says such and such" pissing match. That reminds me of the crap that transpires on the mailing list. This is not about personalities & personal heroes. Please understand, I don't want to cast dispersions towards anybody. I respect those gentlemen too. But by bringing names into the discussion like that, you're setting us up to do just that if somebody disagrees with them. I refuse to be drawn into that situation. I can respect somebody but still believe they are wrong about a particular issue.
I would prefer a good written debate where principles of engineering are discussed. Quoting somebody you respect does not prove the point you may be trying to make. The only reason I can see for doing that is to attempt to end the discussion.
I can see that the Pantera's cooling system is a touchy subject for some. I'll try to respect that, but at the same time, if there are any "myths" floating around in the Pantera community, I would like to bust them, how about you?
Originally posted by johnk:
Where does one find a 160* Cleveland thermostat? I only see Robertshaw listings at 180* and 192*. Thank you
John, to my knowledge, there isn't a 160 degree t-stat on the market for the Clevo, those are Windsor t-stats.
