Dear Jack
Most cars and vintage mustangs, have the lower radiator hose going to water pump and the upper radiator hose going to the thermostat.
I have seen refernece to the orginal hoseing on the radiator to be the opposite. My Mangusta's lower hose on the radiator, passange side is going to the water pump and top driver side hose going to thermostat, the standard vintage Mustang way.
Which is better for Mangusta or the Pantera? the way the factory set it up lower hose to thermostat and upper hose to water pump, so the heat can go from bottom to top of radiator? Or does it not matter?
Thanks for your comments.
