I have a set of new cowl grills (w/o the holes) which were purchased several years ago from one of the pantera vendors. They have never been used! If interested, contact me (wparmele@hotmail.com). Thanks
BE CAREFUL! I used a 9o degree ice pick, and lift from one corner until the grill "popped" from the grommet, repeated on all four corners, and 2 in the middle. If you look carefully at the picture of my grill from behind, you can see the mounts. Mark
